RE: Alfa Zagato Registers - Nurburgring TZ-2's - 452
di feb 03, 2009 17:49
Maar ik ken geen andere foto's uit deze serie... (of een andere auto in dezelfde setting).
Jij wel?
AR110AF
wo feb 04, 2009 13:02
There are three more pictures some pages further in Alleggerita, of which two do show the TZ2, and one shows only the GTAs. I cannot quote pages reference, as pages are not numbered in that book.
On the other pics, the TZ2 can be seen from behind and right side. There's no hole it the right C-pillar neither, confirming it as a new car. There seems to be no registration plate, and the fourth pic is captioned "early 1966".
Adriaenssens caption quoting the car as 106 relies on the reg plate fitted to the bonnet (UD111832), but as I wrote yesterday, that's exactly where he is wrong: the bonnet doesn't belong, originally, to that car, and has clearly the Monza 66 features (recesssed fog lamps fairing were first seen at Monza on April 25th, not TF as I wrote yesterday) , thus the pictures have been taken at soonest in May 1966, but also possibly quite later.
If we consider the featured TZ2 as new (i.e; noot yet raced at the time), the possibilities are:
750117, but it is not her, as the picture shows "normally" located door handles, where 117 has them higher than standard on the door.
750115 has a certificate of origin dated 29/3/66 and no regisration known. It can fit. But 115 has also pretty high door handles, albeit not so much as 117, and the car here has a rear view mirror where 115 has not, at least in current form.
750116 could be a candidate, but it has received UD121003 on March 11 1966, so ity's strange the car seems not to be registered in May pictures. But since it had not raced at Sebring, Monza nor TF, the lack of C-pillar holes is plausible.
An unsolved question I have been trying myself at a few years ago without success... ](*,)
Pericoloso
ma feb 09, 2009 00:35
Zaagmans, heb jij de chassisnummers van de Auto's bij Stolze al ondertussen? Zo niet, dan heb ik er ieg 2 van de 3 voor je met kentekens. Zal morgen de foto's even overpompen. Ik hoor het wel.
SCARB 680.
wo feb 11, 2009 19:02
Zal Alleggerita er binnekort even bij pakken. Gaat wel lukken.
Nee, de Stolze chassisnummers heb ik nog steeds dus alle info is ZEER welkom!
Intussen een oude foto opgeduikeld van TZ-2 # 750113 tijdens de Targa Florio 1966. Ik had hem er al digitaal op staan maar nu dus ook als "vintage afdruk" in de archieven geschoven EN een hi-res (zo ver de korrel van de foto dat toelaat) scan gemaakt.
Nu valt me 1 ding op en dat is dit opstaande witte randje.... Is het gezichtsbedrog? Of wat is het?
AR110AF
Re: RE: Alfa Zagato Registers - Nurburgring TZ-2's - 452
wo feb 11, 2009 19:49
The concrete pillar on the eve of the road... :wink:
RE: Alfa Zagato Registers - Een wit randje... - 452
wo feb 11, 2009 20:36
Maar er lijkt iets over de deur zelf te lopen....
pepijn
wo feb 11, 2009 20:40
;) das een: "spoiler om te voorkomen dat de bijrijders deur openwaait" ;)
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
wo feb 11, 2009 22:02
En dat klopt precies, vergelijk maar met deze foto:
Eigenlijk is het enige mysterieuze dus nog het zwarte stipje
pepijn
wo feb 11, 2009 22:06
Das: "de popnagel" om "de spoiler die voorkomt dat de bijrijders deur openwaait" vast te zetten ;)
wo feb 11, 2009 23:11
Dat die Zaag zich zo druk maakt om een enkele popnagel! Snap jij dat nou? :lol: :wink:
wo feb 11, 2009 23:13
The famous "rivet count".... :wink:
Pericoloso
do feb 12, 2009 00:28
Jack, de nummers van Stolze Zagato's ( 2 van de 3 i.e.g. ) komen eraan. Moet de foto's nog even op de pc knallen. Maar deze heeft kuren..... Daarnaast vrijdag op vakantie, dus morgen de auto pakken. Nog even een weekje geduld, maar het komt goed.
SCARB 680.
do feb 12, 2009 00:34
Geen haast!
Alle input is in eigen tempo welkom!
Pericoloso
do feb 12, 2009 10:41
Morgen wel even haast: kijken of we de 250 op de autobahn kunnen toucheren.......
SCARB 680.
vr feb 13, 2009 23:02
'07 Saab 9-7X 5.3i V8
