Exception EConvertError in module KWP71Diag.exe at 00058246. '2.01389E' is not a valid floatin point value.
From SysUtils.pas(Delphy):
{ StrToFloat converts the given string to a floating-point value. The string
must consist of an optional sign (+ or -), a string of digits with an
optional decimal point, and an optional 'E' or 'e' followed by a signed
integer. Leading and trailing blanks in the string are ignored. The
DecimalSeparator global variable defines the character that must be used
as a decimal point. Thousand separators and currency symbols are not
allowed in the string. If the string doesn't contain a valid value, an
EConvertError exception is raised. }
enjoy
