ericj
RE: Looking for a Reliable Alfa Mechanic in Den Haag Regio
vr jun 19, 2009 23:27
Can't help you with that, but since you're not sure that something is wrong with your AFM/LMM, why not post a question in the "Algemene technische vragen" section of this forum. Maybe somebody has tips or a spare you can try.
You could try simply disconnecting the AFM. If this doesn't cure the problem it can't be the AFM going bad, it must be something else.
Eric
haesbe
wo jun 24, 2009 15:07
Ok. I finaly found the problem of my Alfa GTV. It wasn't the LMM but two sparks were floating in the engine oil. The mechanic from Auto Romeo Nootdorp changed the rubber seals and cleaned the connectors and now everything works well. The computer scan didn't reveal any faults though.
Animale Bianco
di jul 14, 2009 19:32
Glad you're issue is gone for now with just a simple repair. Would be nice if everything could be solved so easily :-)
Spec: 258pk / 287Nm
Tune: KW Var.2 - Carbon GTA-Line tube - EtaBeta 20" Tettsut black - 225/30 R20 - SkyTune 2x TwinOval - Novitec soundpipe - Momo Millenium Evo - Ferodo DS2500 - CTF grooved discs - carbon plenum - F430 throttle body - BMC CDA
