found a spring between rear transaxle and car body (Giulia)
Geplaatst: ma mei 08, 2006 21:24
and couldn´t find it in my literature ( repiar books and parts list). So I asked an Alfa master mechanic who had never seen a spring in that location before.
There´s a rubber cap on top of the rear transaxle holding the bottom of the spring in place and a metal plate giving it hold on the top.
All parts are italian made ( reading BREV. bologna) and seem to be professionally made for the car.
The only function I could imagine is , that the spring is an additional part for higher trunk load (maybe for LPG tank which had been installed once)
I removed the spring which was working easily and got an additional rear drop of about 2 cm`s ( Eibach lowering springs and Koni yellows installed , rear always looked "pumped up" before removing the spring of mystery.....)
So my question is: Can anyone tell me the real function of this spring construction???
