Mathijs Spider 2000
Re: RE: GT Legends......................online met een GTA (
do dec 01, 2005 21:34
wat doet die update dan?
Bepaalde online dingetjes :D zijn verbeterd.
1. Fix for intermittent missing car shadows in MP.
2. Fix for slow loading game clients missing race starts in MP.
3. Fix non-scrolling client grid list.
4. Fix for missing wheels in dedicated server replays.
5. Fix for intermittent invisible cars with shadows.
6. Fix for MP lobby sort crashes/hangs.
7. Dedicated server now supports a maximum of 36 cars.
8. Alt-tab stability improvements.
9. Various localisation fixes.
10. Loss of client connection to lobby no longer causes immediate disconnect from game server.
11. Fix for inverted mirrors in Ford Escort.
12. Various car model/paint improvements.
13. Fix for Spa corner cutting problems.
14. Fix for Imola and Magny-Cours locked garage door in MP.
15. Improve braking marker visibility at Anderstorp.
16. Fix for incorrect lap records in MP.
17. Fix for missing opponent laptimes when joining MP qualifying session.
18. Cup system unlockable track fixes.
19. Fix for missing brake markers at Imola and Zolder under lower detail level settings.
20. Fix for two cars sharing one garage at Donington.
21. Shadows optimised.
22. Fix for dedicated server intermittently failing to connect to the lobby over slow connections.
23. "Low" shadows option now shows ambient car shadow.
24. Fix for missing Mercedes 300SL external idle sounds.
25. Left Alt + F key manually resets force feedback.
26. Lobby password now gets saved between sessions.
27. Race length now shown in MP monitor screen.
28. Fix for badly mapped spectator cars at Zolder.
29. Fix for lobby lap sorting done alphabetically bug.
30. Automatic startup option (+auto) added to dedicated server.
31. Results file now includes car number.
32. Fix for premature brake failure with some cars.
33. F12 screenshots saved as TGA, not JPG.
34. Fix for duplicate screen grabs in replay mode.
35. Fix for best lap times from prac/qual appearing in race statistics.
Remco S
RE: GT Legends......................online met een GTA (Bert
vr dec 02, 2005 12:55
ja, eerst vragen, dan kijken, ik zag het na het downloaden ook staan.
ps. vandaag de heldag op Spa met de GTA gereden, en ik moet toegeven die baan klopt 100%, zelf de verbreede gurb stones zijn aanwezig :thumbs: baan!!!!
__________
Alfa Giulietta 2.0. 1984
Woody34
vr dec 02, 2005 13:19
Nu nog de Nordschleife erin en je hoort mij niet meer zeuren.
Proud owner of:
Alfasud Sprint 1.3S 1983
Remco S
vr dec 02, 2005 13:45
zandvoort is in mijn geval een pré
__________
vr dec 02, 2005 15:59
Ben nog in twijfel of ik het spel ga kopen, zijn de grafix vergelijkbaar met GP4 ?
En de speelbaar heid hoe zit het daar mee :roll:
Daarnaast heb ik maar 512 mb geheugen en dat is op zn minst nodig :shock:
Ben alvast ff de demo binnen aan het halen........
Mathijs Spider 2000
vr dec 02, 2005 16:10
De graphics zijn vele malen mooier als die van GP4. Kijk maar bij het eerste bericht. Het spel is zeer goed speelbaar (niet gemakkelijk) als je van simulatie en niet van arcade houd. Het is n.l. best een realistisch spel qua handeling :driving: . Ook de afstellingen die je moet/kunt doen aan de auto hebben direct effect op het rij/rem/weg gedrag. Indien je online speelt is de realiteit nog groter omdat je tegen gamers speelt die veel afstellen e.d. auto. Wil je zelf niet afstellen dan zijn er online setups te downloaden die andere spelers hebben neergezet.
In de demo zitten een aantal auto's die totaal verschillend van elkaar zijn qua handeling. Ik hoop dat je overtuigd bent. En nee ik ben geen verkoper voor Simbin (producent) :D
vr dec 02, 2005 16:14
Oke hier kan ik wat mee, wel nog eerst ff de demo spelen.....
Iemand ervaring met de 512mb geheugen, zou het een belemmering zijn.
En nee, ik kan helaas niets bijplaatsen, 2 banken van 256 zijn bezet.
Het betreft RIMM geheugen, vandaar :!:
Remco S
vr dec 02, 2005 16:30
officieel moet je 512 mb ram hebben, is het niet dat ik 265 heb, ik kan het spel spelen het enige is dat op het moment dat je de box uitrijd het beeld even stotterd. Ik ben wel van plan dit uit te gaan breiden, tips?
oja ik heb een radeon 9200 videokaart
__________
Mathijs Spider 2000
vr dec 02, 2005 16:59
Ik heb nog niet zo lang geleden een nieuwe pc aangeschaft, amd 64 3200, 1056 intern, 2 vidiokaarten (SLI) en zelfs als ik alles maximaal zet wil het bij mij nog wel eens stotteren. Dus gewoon uitproberen met de graphics, laag beginnen en steeds meer grafische elementen activeren. Dan kun je zien of het soepel blijft lopen. Aan een stotterende baan heb je niet zo veel.
Schaduw en details zo laag mogelijk houden van d.v. de omgeving maakt dat het allemaal wat soepeler loopt.
vr dec 02, 2005 17:46
Euh ja normaliter geeft het spel zelf al aan welke de beste instelling quality/performance zijn .
Daar vanaf wijken kan uiteraard met de beperking dat het spel niet 100% lekker loopt.
De demo heeft blijkbaar rond 270 mb geheugen nodig, net ff getest.
Een standaard XP configuratie met alles erop en eran zit snel op 225 mb geheugen!!!!
Zeker als je veel pakketten adobe installeerd etc en allerhande "rommel" zit je heel snel hoger.
Eea, is ook weer afhankelijk van type pc/moederbord en benodigde drivers....
Met 512 mx zit je dus heel snel te swappen en das niet bevordelijk voor je snelheid.
Een optie zou kunnen zijn om je swap vast te zetten zodat je met een vast waarde werkt en dus processorcap. (rekenkracht) kunt gebruiken voor het spel!!!!
Swapgrootte is ca 2.5 x beschikbare geheugen cap.
Remco S
vr dec 02, 2005 21:52
wordt de race woensdag donnington national of gp?
__________
Woody34
vr dec 02, 2005 23:05
maakt mij niet uit. Ik vind ze beide leuk
Proud owner of:
Remco S
za dec 03, 2005 09:48
Op het moment is bij mij alleen nog donnington national geopend, ik denk ook als er meerdere mee doen (weet natuurlijk niet hoever die zijn) je hem niet te hoog in moetr stellen.
op welke moeilijkheid word er dan gespeeld?
Want dan weet ik of ik nog even een volle dag moet spelen om wat verder te komen :lol:
maar count me in!!!!!
__________
Mathijs Spider 2000
za dec 03, 2005 10:00
Ik zal voor de rookies :lol: onder ons een aantal opties open laten. Je kunt dan zelf bepalen hoeveel hulp je aan wilt laten. Maar Remco ik dacht dat jij zoveel race ervaring had???? :twisted:
Remco S
za dec 03, 2005 12:14
in het echt heb ik redelijk wat ervaring (ben geen schumi, al heeft die dit jaar ook nix laten zien) maar op de computer is het toch wat anders hoor, het gevoel met de auto ontbreekt he!!
__________
